Automotive Embedded system
hn1
I am a beginner in automotive embedded system.
Can any one suggest me good reference about that.
Added after 8 minutes:
I saw some thing about CAN in automotive .
can you explain how I can use it?
btbass
Advanced Member level 5
Oberon
Check out MISRA web site, The Motor Industry Software Reliability Association.
I suggest you invest in the book
'MISRA-C:2004
Guidlines for the use of the C language in critical systems.'
Then you will need a program like PC-lint from Gimpel Software so you can check your code for Misra compliance.
CAN bus is used in automotive. A lot of info and sample code can be found at Microchip.
hn1
I saw an article about POLIS software. Can anybody suggest me a good software for automotive embedded systems
btbass
Oberon
The language of choice for Automotive embedded is C. You just need an Ansi C compiler for the chipset you are using. The code has to comply with the Misra rules. That why you need the book.
hn1
how about POLIS? anybody has comment?
hn1
Is OSEK an operating system for all automotive systems?
ariyan
Member level 5
I have one query. Is all automotive embedded system uses MATLAB. Mainly which language is used in automotive embedded C or C++ or Java?
hnejati
Member level 3
I prefer the CCSS by synopsis
    hn1
