Automatic Railway Gate Control
amon mazhara
Can someone help me to design an automatic railway gate control using a microcontroller like pic16f877
What functions do you want in the program. How do you sense that train is coming or train has gone to close or open the gate?
The circuit should just sense the train at a certain distance and give a signal and close the boom gate and then opens it when the train had left
Is your boom gate controlled by a motor? How do you sense the train coming or going?
Yes the boom is to be controlled by a motor and the train can be sensed by transmitter and receiver circuits or any other means necessary
The code for 8051 is given in the document. Can you translate it for PIC?
Can I use external interrupt to sense the IR signal? How many IR sensor pairs are there?
I think IR output can be given to INT0 interrupt. If a burst of IR is detected on INT0 pin then according to it action can be taken.
Can you use the circuit mentioned here? http://www.8051projects.net/t40251/electronics/ir-led-tsop-1738.htm
