Automatic change over
gfactor
Junior Member level 1
Lagos, Nigeria
Pls I need a circuit that will automatically switch over to generator and back to electricity mains when there is supply with alarm. Also considering when there's low voltage from mains
santoshaxl
Advanced Member level 2
some where left alone
you have to tell me your generator is 3 phase or single phase generator
    V
nandhu015
Advanced Member level 5
India
Simple solution is power a relay with mains and connect the mains in normally open and generator in normally closed positions.
There are relays available which will operate in 230V
pranam77
INDIA
This can be achieved just by using relays. But to use it you must be able to think how. Its nothing but switching by the relay contacts. Cheers and good luck
amjadali56
Full Member level 3
Earth
here is a simple circuit for ur requirement.
single Phase, adjustable low voltage cut out, LED and Buzz for main voltage.
need more advancement requirement or any help?
pranam77
INDIA
here is a simple circuit for ur requirement. single Phase, adjustable low voltage cut out, LED and Buzz for main voltage. need more advancement requirement or any help?
Why complication while the same function can be achieved just by relays? In case of low voltage you'll have to start the generator first and not Shifting the load to the generator. Why one will sit in the dark unless the generator is activated at the same time. This circuit shown below is commercially used for changeover.
Cheers
amjadali56
Full Member level 3
Earth
excellent point Pranam! a man with a thinking mind..........
ibitechs2005
Member level 3
Nigeria
This is the right place to be,in term of good and acurate infomation about functional circuits.Thank you.............
joshnosh
2 problems you still have to start the generator or leave it running
and the sudden change and lack off power until its running from the generator will make most devices reset
chuckey
Southampton and holiday cottage in Wensleydale (UK
I was going to mention that. sequence is :- 1. mains fails(goes low) 2. generator starts 3. generator volts stable for 5 seconds. 4. change over to generator. 5. mains returns and is stable for 10 seconds. 6 change over to mains. 7. generator runs for 10 minutes for cooling system and alternator cooling to cool things down then generator switches off.
Frank
Andy G
Member level 2
whats the KVA rating of the generator?
is it a portable gasoline(petrol) generator?
pranam77
INDIA
I was going to mention that. sequence is :- 1. mains fails(goes low) 2. generator starts 3. generator volts stable for 5 seconds. 4. change over to generator. 5. mains returns and is stable for 10 seconds. 6 change over to mains. 7. generator runs for 10 minutes for cooling system and alternator cooling to cool things down then generator switches off. Frank
Thank you Frank for the flow chart. In simple the circuit given by me is typical Indian design. (Keep it cheap and simple). In addition to that it also has a 12 volt 500 Ma transformor driving a 12 volt SPDT relay which is energised when the power resumes to switch off the engine. No timers are used. But your idea is excellent and advanced with which one can design a complete changeover system.
Cheers
ibitechs2005
Member level 3
Nigeria
But one may need a snapy so that some of the load does not reset,do you think this timming won't cause this?
