auto correlation and cross correlation values
abhigopal
Member level 3
Hi all,
I have a question! I have a vector( array of elements) and I need to compute the auto-correlation matrix for this. How do I do it in Matlab. This matrix needs to be toeplitz and symmetrical.
Also on the same lines, How do i perform cross correlation between 2 sets of elements (arrays again) using matlab.
I need all this because of work I am doing in Statistical Signal Processing,
Thanks all
Abhi
Just use 'xcorr' function. see help for the useage.
all these these r given in matlab tool box just take help from thre.
hi if x is a row vector then xTx shd give u auto correlation matrix whic is symmetric and Toeplitz.
matlab code is
R = x'.*x;
this will give u the Auto correlation matrix
thnx
purna
performing what you suggested:
>> x=rand(1,5)
x =
0.7621 0.4565 0.0185 0.8214 0.4447
>> R=x'*x
R =
0.5808 0.3479 0.0141 0.6260 0.3389
0.3479 0.2084 0.0084 0.3749 0.2030
0.0141 0.0084 0.0003 0.0152 0.0082
0.6260 0.3749 0.0152 0.6747 0.3653
0.3389 0.2030 0.0082 0.3653 0.1978
Sorry it is not a toeplitz
abhigopal said:
Hi all,
I had the same doubt as you, and I still dont know if I achieved the solution, I will share it , and I will be glad if I had comments:
the crosscorrelation matriz is quoted in AR, ARMA methods, LMS, RLS and many others, it is a toeplitz hermitian matrix.
Lets consider a randon set of data and find the autocorrelation matrix:
>> x=rand(1,5)
x =
0.6154 0.7919 0.9218 0.7382 0.1763
>> r=xcorr(x)
r =
0.1085 0.5939 1.3144 2.0280 2.4317 2.0280 1.3144 0.5939 0.1085
>> R= toeplitz(r)
R =
0.5939 0.1085 0.5939 1.3144 2.0280 2.4317 2.0280 1.3144 0.5939
1.3144 0.5939 0.1085 0.5939 1.3144 2.0280 2.4317 2.0280 1.3144
2.0280 1.3144 0.5939 0.1085 0.5939 1.3144 2.0280 2.4317 2.0280
2.4317 2.0280 1.3144 0.5939 0.1085 0.5939 1.3144 2.0280 2.4317
2.0280 2.4317 2.0280 1.3144 0.5939 0.1085 0.5939 1.3144 2.0280
1.3144 2.0280 2.4317 2.0280 1.3144 0.5939 0.1085 0.5939 1.3144
0.5939 1.3144 2.0280 2.4317 2.0280 1.3144 0.5939 0.1085 0.5939
So R is a toeplitz and Hermitian matrix built with the autocorrelation of x. Is it right ?
Thanks all
Abhi
To perform crosscorrelation you take the two set of data x1,x2 and use the comand xcorr1(x1,x2) care must be taken when the signals are periodic and of different lengths, in this case you have to zero pad N2-1 zeros to x1 and N1-1 zeros to x2 where N1 and N2 are the length of x1 and x2.
