i have now the result of my audio digital transmision over the WAN and LAN.
on WAN, it uses fiber optic.
and on LAN uses common wires for LAN (UTP)
this is a one way audio transmision..
i record the sender audio and also the receiver audio by using the Window recorder..
now the problem is, how would i compare the result..
or maybe my question would be, is there a software use to compare this samples??
i did try use GoldWave, and uses its sperctrom function,
but im new to goldwave and im not also sure if it would do the comparision.....
the comparison would be obviosly, the diference betwen the reciever and the sender...
hoping for a respones..thanks...
or maybe a book for it...
