hi everyone. i am using TDA7388A audio amplifier to run 4 speakers each having 4 OHMS impedance. my supply rail is of 16V max. can u suggest how to calculate the power descipation in audio amplifier.
thanks in advance.
You can refer to Figure 10 in the datasheet, scaling the numbers with (16/13.2)², resulting in nearly 55 W maximum power dissipation with sine signals. The typical power dissipation playing music will be considerably lower according to the magnitude statistics.
