Ducados
Junior Member level 1
I have built a small amplifier based on actual designs suggested by the datasheet of the TDA 2004 (8 watt stereo). This works fine with my guitar effects pedals, It's surprisingly loud, clear and with little distortion.
I then built a stereo preamplifier based on the TLA071 opamp, again with a design included in the datasheet (gain 10:1, non inverting input). The preamp also works fine, hardwired to the other amplifier with an MP3 as a source
The problem is that when I plug in both input jacks, the sound quality deteriorates, especially the Roland effects pedals. I also noticed a small reduction in sound quality when I implemented the volume controls. Do I need to make the inputs
"invisible" to each other or would the problem most likely be impedance?
Any advice appreciated.
