attiny2313 serial interface with baudrate 115200
acus
Junior Member level 1
attiny2313 serial
pleasee anyone help me.. i want to build project wih attiny2313 serial comunication with baudrate 115200 heres some example:
$regfile = "attiny2313.dat"
$crystal = 20000000
$baud = 115200
Dim Cr As Byte
Cr = &H0D
Config Com1 = 115200 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Waitms 5
Print "acus kasep pisan" ; Chr(cr);
End
i have test with avr simulator and works fine but if i conect with pc (hyperterminal) it's not working. the result is not "acus kasep pisan"
any solution...? i try with crystal external 4mhz,20mhz still not working...
attiny2313 project
I think it is the problem with fuse bits. Default frequency of most of atmega uC are 1mhz, so if you are using 115.2kbps, see the error. If it is .2% then it is ok. Read fuse bits and program fuse bits for external crystal. Since it is not working for 4mhz and 20mhz, it is almost sure that fuse bits is the problem. See this link to know about setting fuse bits
Bibin John
www.bibinjohn.tk
attiny2313 baudrate
thanks for reply @yogi.. i'm snewbie in avr... how to setup the fuse bit for external crystall in bascom..??
attiny13 serial
it depends on the programmer, not to do with bascom. See how i had done, and do the same with refering to your datasheet, just set lfuse and hfuse
Bibin John
www.bibinjohn.tk
