[ARM] Attemp to run Cortex-M1
Navrys
Newbie level 1
I'm trying to run my first code on ARM Cortex-M1 soft processor. It is quite complicated process for me and there are many steps where I could make some mistake. But now I have:
1) VHDL project and bitstream loaded into ProASIC3L FPGA,
2) simple C program to turn on one LED connected to GPIO output.
But when I try to run it in Debug configuration in SoftConsole IDE I get:
source .gdbinit
set arm fallback-mode thumb
target remote | "C:/Program Files (x86)/Microsemi/SoftConsole v3.4/Eclipse//../Sourcery-G++/bin/arm-none-eabi-sprite" flashpro:?cpu=Cortex-M1 "F:/Workspace/libero/cortexm1_1/SoftConsole/cortex_m1_system_CortexM1Top_0/cortex_m1_system_CortexM1Top_0_app/Debug"
arm-none-eabi-sprite: Using memory map F:/Workspace/libero/cortexm1_1/SoftConsole/cortex_m1_system_CortexM1Top_0/cortex_m1_system_CortexM1Top_0_app/Debug/memory-map.xml
arm-none-eabi-sprite: Target reset
0x00000080 in frame_dummy ()
set mem inaccessible-by-default off
load
Loading section .text, size 0x378 lma 0x0
Loading section .data, size 0x4 lma 0x378
Start address 0xc8, load size 892
Transfer rate: 19 KB/sec, 446 bytes/write.
monitor debug-reset
thb main
Hardware assisted breakpoint 1 at 0x96: file ../main.c, line 16.
cont
Program received signal SIGTRAP, Trace/breakpoint trap.
0x00000000 in vector_table ()
Could you help me to figure out where I'm doing a mistake? I could upload full project, but maybe it is better to go step by step starting from the informations presented above. Does it give any clue?
