ATPG libraries simulation with mentor DFT tools
feel_on_on
Full Member level 5
libcomp mentor
hi,all
mentor DFT tools have to translate verilog simulation library to DFT libraries.
But when I verify DFT libraries with IcVerify command . It invoke a modelsim .
I currently have ncverlog simulator . if I need to verify DFT libraries translated from verilog simulation libraries with ncverilog ,what i should do ?
Thanks
mentor libcomp usage
If I were you, I'd just inspect your log file generated by the libcomp - and iff there are no problems, just use the library - don't worry about simulating it. I've had decent luck with that approach.
John
DFT Digest
how to translate verilog to fastscan library
so you do DFT with mentor tools too ? if libcomp generate log file report a Mismatch?
verilog atpg to mentor dft
I've used boh Mentor and Synopsys tools in the past.
There was a situation where libComp generated a warning about an unsupported udp construct of some sort. And it caused no problem immediately, because the design did not use that cell - but later on it did, and the ATPG did not work, and it took me awhile to figure it out.
Most standard cell library vendors (TSMC, Artisan, etc.) provide a Mentor library with the library. Make sure you don't have that before using libComp instead.
John
DFT Digest
dft libcomp
cell librares is our company'libraries,So I have to generte a mentor library.
there some warning about notifier when I libComp.
I want to know if u simulate the ATPG library with modelsim? or with others tools . As if u need not simulate the ATPG libraries
libcomp
No, I did not simulate with Modelsim - what I did was trust the results, as long as there were no warnings in the libComp log file. But I was the only user of the FastScan library.
Now if I were developing a library for other's use, I'd find a way to hack the verify script and simulate it.
What warnings are you seeing?
John
atpg library
libComp log show no warning and error.But fastscan report some warning as following:
Net 'notifier' in model is floating
vcond1 in model is unused.
atpg fastscan tiex
Seen that before. It's not really an issue, because as you may know , notifiers are for simulation, and flag timing violations and such, which have nothing to do with ATPG.
That said, however, it seems libComp should at least hook those up with tiex primitives, so you don't get the message.
