unsigned int adc_rd;
void main() {
DDRB = 0xFF; // set PORTB as output
DDRC = 0x3E; // set PORTC.0 as input for ADC
DDRD = 0xFF; // set PORTD as output
PORTB = 0x00;
PORTC = 0x00;
PORTD = 0x00;
REFS0_bit = 1; // use AVCC as VRef
while(1) {
adc_rd = ADC_Read(0); // get ADC value from 0th channel
PORTB = adc_rd; // display adc_rd[7..0]
PORTD = (adc_rd >> 8); // display adc_rd[9..8]
Delay_ms(300);
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 _main: LDI R27, 255 OUT SPL+0, R27 LDI R27, 0 OUT SPL+1, R27 LDI R27, 255 OUT DDRB+0, R27 LDI R27, 62 OUT DDRC+0, R27 LDI R27, 255 OUT DDRD+0, R27 LDI R27, 0 OUT PORTB+0, R27 LDI R27, 0 OUT PORTC+0, R27 LDI R27, 0 OUT PORTD+0, R27 IN R27, REFS0_bit+0 SBR R27, BitMask(REFS0_bit+0) OUT REFS0_bit+0, R27 L_main0: CLR R2 CALL _ADC_Read+0 STS _adc_rd+0, R16 STS _adc_rd+1, R17 OUT PORTB+0, R16 MOV R16, R17 LDI R17, 0 OUT PORTD+0, R16 LDI R18, 7 LDI R17, 23 LDI R16, 107 L_main2: DEC R16 BRNE L_main2 DEC R17 BRNE L_main2 DEC R18 BRNE L_main2 NOP JMP L_main0 L_end_main: L__main_end_loop: JMP L__main_end_loop ; end of _main
Okada, again: read datasheets before posting trivial questions.Initially I think the PORT will be configured as output pins in a blank AVR. Right ?
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 /******************************************************* This program was created by the CodeWizardAVR V3.28 Automatic Program Generator © Copyright 1998-2016 Pavel Haiduc, HP InfoTech s.r.l. [url]http://www.hpinfotech.com[/url] Project : ADC Example Version : 1.0 Date : 12/10/2016 Author : Okada Company : Comments: Example to read ADC input. Chip type : ATmega8A Program type : Application AVR Core Clock frequency: 4.000000 MHz Memory model : Small External RAM size : 0 Data Stack size : 256 *******************************************************/ #include <io.h> #include <delay.h> // Declare your global variables here // Voltage Reference: AVCC pin #define ADC_VREF_TYPE ((0<<REFS1) | (1<<REFS0) | (0<<ADLAR)) unsigned int adc_result = 0; // Read the AD conversion result unsigned int read_adc(unsigned char adc_input) { ADMUX=adc_input | ADC_VREF_TYPE; // Delay needed for the stabilization of the ADC input voltage delay_us(10); // Start the AD conversion ADCSRA|=(1<<ADSC); // Wait for the AD conversion to complete while ((ADCSRA & (1<<ADIF))==0); ADCSRA|=(1<<ADIF); return ADCW; } void main(void) { // Declare your local variables here // Input/Output Ports initialization // Port B initialization // Function: Bit7=Out Bit6=Out Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=Out DDRB=(1<<DDB7) | (1<<DDB6) | (1<<DDB5) | (1<<DDB4) | (1<<DDB3) | (1<<DDB2) | (1<<DDB1) | (1<<DDB0); // State: Bit7=0 Bit6=0 Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=0 PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (0<<PORTB0); // Port C initialization // Function: Bit6=Out Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=In DDRC=(0<<DDC6) | (0<<DDC5) | 0<<DDC4) | (0<<DDC3) | (0<<DDC2) | (0<<DDC1) | (0<<DDC0); // State: Bit6=0 Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=T PORTC=(0<<PORTC6) | (0<<PORTC5) | (0<<PORTC4) | (0<<PORTC3) | (0<<PORTC2) | (0<<PORTC1) | (0<<PORTC0); // Port D initialization // Function: Bit7=Out Bit6=Out Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=Out DDRD=(1<<DDD7) | (1<<DDD6) | (1<<DDD5) | (1<<DDD4) | (1<<DDD3) | (1<<DDD2) | (1<<DDD1) | (1<<DDD0); // State: Bit7=0 Bit6=0 Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=0 PORTD=(0<<PORTD7) | (0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0); // Timer/Counter 0 initialization // Clock source: System Clock // Clock value: Timer 0 Stopped TCCR0=(0<<CS02) | (0<<CS01) | (0<<CS00); TCNT0=0x00; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: Timer1 Stopped // Mode: Normal top=0xFFFF // OC1A output: Disconnected // OC1B output: Disconnected // Noise Canceler: Off // Input Capture on Falling Edge // Timer1 Overflow Interrupt: Off // Input Capture Interrupt: Off // Compare A Match Interrupt: Off // Compare B Match Interrupt: Off TCCR1A=(0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10); TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (0<<CS11) | (0<<CS10); TCNT1H=0x00; TCNT1L=0x00; ICR1H=0x00; ICR1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; // Timer/Counter 2 initialization // Clock source: System Clock // Clock value: Timer2 Stopped // Mode: Normal top=0xFF // OC2 output: Disconnected ASSR=0<<AS2; TCCR2=(0<<PWM2) | (0<<COM21) | (0<<COM20) | (0<<CTC2) | (0<<CS22) | (0<<CS21) | (0<<CS20); TCNT2=0x00; OCR2=0x00; // Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=(0<<OCIE2) | (0<<TOIE2) | (0<<TICIE1) | (0<<OCIE1A) | (0<<OCIE1B) | (0<<TOIE1) | (0<<TOIE0); // External Interrupt(s) initialization // INT0: Off // INT1: Off MCUCR=(0<<ISC11) | (0<<ISC10) | (0<<ISC01) | (0<<ISC00); // USART initialization // USART disabled UCSRB=(0<<RXCIE) | (0<<TXCIE) | (0<<UDRIE) | (0<<RXEN) | (0<<TXEN) | (0<<UCSZ2) | (0<<RXB8) | (0<<TXB8); // Analog Comparator initialization // Analog Comparator: Off // The Analog Comparator's positive input is // connected to the AIN0 pin // The Analog Comparator's negative input is // connected to the AIN1 pin ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0); // ADC initialization // ADC Clock frequency: 125.000 kHz // ADC Voltage Reference: AVCC pin ADMUX=ADC_VREF_TYPE; ADCSRA=(1<<ADEN) | (0<<ADSC) | (0<<ADFR) | (0<<ADIF) | (0<<ADIE) | (1<<ADPS2) | (0<<ADPS1) | (1<<ADPS0); SFIOR=(0<<ACME); // SPI initialization // SPI disabled SPCR=(0<<SPIE) | (0<<SPE) | (0<<DORD) | (0<<MSTR) | (0<<CPOL) | (0<<CPHA) | (0<<SPR1) | (0<<SPR0); // TWI initialization // TWI disabled TWCR=(0<<TWEA) | (0<<TWSTA) | (0<<TWSTO) | (0<<TWEN) | (0<<TWIE); while (1) { // Place your code here adc_result = read_adc(0); PORTB = adc_result; PORTD = adc_result >> 8; delay_ms(300); } }
>CALL _ADC_Read+0code related to ADC_Read() function.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 void main() { DDRB = 0xff; DDRD = 0xff; ADMUX = 0x40; //1<<REFS0, cnl0 ADCSRA = 0xE7; //1<<ADEN|1<<ADSC|1<<ADFR|7; while(1) { PORTB = ADCL; PORTD = ADCH; } }
mb it is necessary to create new project ? or add "#include <mega8.h>" string.it is not working with CodeVisionAVR
@Okada, up to now, I'm still not able to get what exactly do you mean by 'not working'. Instead of chaotically jumping from one code to another, stay with a single one which worked in simulation and try to follow a methodical process. It is clear that since there is no issue in firmware side, but in hardware, therefore only you are able to check this locally. By the way, the original circuit sounds quite minimalist and with very low decoupling capacitor or even the lack of it to be mounted on a prototyping board, as you are supposed to be doing.In Proteus it i sworking fine that is both codes but not on hardware
Still not clear, are you saying that the initial issue ( both codes worked in simulation, not in target device ) is now solved
