atmega644p internal pullups
sherazi
Banned
Muscat, Oman, Oman
unable to use internal pull ups for PORTC on ATmega644p
tried this test code with pins not connected to anything , the result expected is blinking LEDS at portb but iam getting them glowing continously as the Leds are sinking current !
int main()
DDRC=0;
PORTC=255;
DDRB=255;
PORTB=0;
while(1)
while (PINC==0xff)
_delay_ms(250);
_delay_ms(250);
PORTB=0;
_delay_ms(250);
_delay_ms(250);
PORTB=255;
PORTB=0;
Whenever I read for an I/O problem in AVRs that have JTAG I immediately think about the JTAGEN fuse.
PORTC is the JTAG port and the JTAG fuse is enabled by default so have you disabled JTAG?
Reactions: sherazi
    sherazi
From the device fuses, set the the JTAGEN fuse to 1 (unprogrammed) to disable JTAG.
Alex
This is described in the datasheet
25.10Programming via the JTAG Interface
Programming through the JTAG interface requires control of the four JTAG specific pins: TCK,
TMS, TDI, and TDO. Control of the reset and clock pins is not required.
To be able to use the JTAG interface, the JTAGEN Fuse must be programmed. The device is
default shipped with the fuse programmed. In addition, the JTD bit in MCUCSR must be cleared.
Alternatively, if the JTD bit is set, the external reset can be forced low. Then, the JTD bit will be
cleared after two chip clocks, and the JTAG pins are available for programming. This provides a
means of using the JTAG pins as normal port pins in Running mode while still allowing In-Sys-
tem Programming via the JTAG interface. Note that this technique can not be used when using
the JTAG pins for Boundary-scan or On-chip Debug. In these cases the JTAG pins must be ded-
icated for this purpose.
During programming the clock frequency of the TCK Input must be less than the maximum fre-
quency of the chip. The System Clock Prescaler can not be used to divide the TCK Clock Input
into a sufficiently low frequency.
As a definition in this datasheet, the LSB is shifted in and out first of all Shift Registers.
I use the JTAGEN fuse.
