ATMEGA32L & PPI (8255) interface question
NTFS
Member level 3
ppi 8255
Hi
In a project I should to handle many I/Os (GLCD, K/B, many lamps, buzzer, 2 fans, 4 sensors, heater and a DC motor ). So I used two PPI (8255) and micro ports.
Now how can I handle PPI control signals? (A0, A1, RD, WR, CS)
I thing, I should do that manually by micro ports, because I couldn't find a method that when I write to PPI, micro does [WR, A0, A1, CS] signals automatically.
So two questions:
1) what is the best method to interface these many I/Os to micro? Is my method good?
2) How to handle control signals? if I active these signals at a same time, does PPI
work? or I have to do them in separate times? for example first I should active
CS, A0, A1 then put data on port (data bus) and then active WR (write) signal
Thanks in advance.
i2c 8255
This ATmega microcontroller had not been designed to co-operate with older PIOs such as the 8255, so maybe you can consider the already built-in two-wire interface, namely the I2C, and expand the number of IOs by adding some PCF8574-s or any other I2C-compatible expanders ..
https://www.i2cchip.com/pcf8574.html
Using 8255s is still an open option, but it can be a little bit tricky, especially if you are not familiar with the multiplexed A/D parallel bus ..
Rgds,
IanP
:D
    NTFS
interfacing ppi to atmega32
Another Simple way is to use a serial in parallel out shift registers
There are a lot of examples of lcd using these chips, google and find one
Nandhu
