kgavionics
Full Member level 3
- Joined
- Jun 12, 2012
- Messages
- 167
- Helped
- 7
- Reputation
- 14
- Reaction score
- 11
- Trophy points
- 1,298
- Location
- Alberta.Canada
- Activity points
- 2,479
Hello guys
I'm learning AVR assembly, and I'm having trouble sending 16bits data to a 74595(shift register). I have successfully written a code that works to send 8 bits data, but somehow it doesn't work (with a little modification of course) for 16 bits data.
to send 16 bits I modified the following code, but the output is always wrong!
Does someone have an idea how to fix this?
Thanks in advance!
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 .device ATmega328P .org 0 ldi r16,low(ramend) out sph,r16 ldi r16,high(ramend) out sph,r16 sbi ddrb,0 ; arduino pin 8 (serial in) sbi ddrd,7 ;arduino pin7 (clock) sbi ddrd,4 ;arduino pin 4 (latch) start: ldi r17,$0f call send call latch here: rjmp here .org $100 clock: sbi portd,7 call delay cbi portd,7 call delay ret .org $120 latch: sbi portd,4 call delay cbi portd,4 ret .org $140 delay: ldi r19,$0f loop2: ldi r20,$ff loop1: nop dec r20 brne loop1 dec r19 brne loop2 ret .org $160 send: ldi r16,$09 ; number of bits to be sent (for some unknown reason 08 sends only 7 bits, so I had to use 9 to send 8 bits clc loop: lsr r17 call clock brcs one cbi portb,0 call delay rjmp go one: sbi portb,0 go: dec r16 brne loop ret
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 .device ATmega328P .org 0 ldi r16,low(ramend) out sph,r16 ldi r16,high(ramend) out sph,r16 sbi ddrb,0 ; arduino pin 8 (serial in) sbi ddrd,7 ;arduino pin7 (clock) sbi ddrd,4 ;arduino pin 4 (latch) ldi r17,$0f ; low byte to be sent call send ldi r17,$f0 ; high byte to be sent call send call latch here: rjmp here .org $100 clock: sbi portd,7 call delay cbi portd,7 call delay ret .org $120 latch: sbi portd,4 call delay cbi portd,4 ret .org $140 delay: ldi r19,$0f loop2: ldi r20,$ff loop1: nop dec r20 brne loop1 dec r19 brne loop2 ret .org $160 send: ldi r16,$09 ; number of bits to be sent (for some unknown reason 08 sends only 7 bits, so I had to use 9 to send 8 bits clc loop: lsr r17 call clock brcs one cbi portb,0 call delay rjmp go one: sbi portb,0 go: dec r16 brne loop ret
Thanks in advance!
