Atmega2560 USART issue with interrupt...
Krv Perera
Newbie level 2
Newbie level 2
// This code waits for a character and transmits the character back (with interrupts)
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
#define F_CPU 16000000UL
#include <avr/io.h>
#include <stdint.h>                     // needed for uint8_t
#include <util/delay.h>
#include <avr/interrupt.h>
#define FOSC 16000000                       // Clock Speed
#define BAUD 9600
#define MYUBRR FOSC/16/BAUD -1
volatile char ReceivedChar;
int main( void )
    //cli();
    DDRB = 0xFF;    //LED off
    PORTB = 0x00;
    UCSR0B |= (1 << RXEN0) | (1 << TXEN0);      // Enable receiver and transmitter
                        //RX interrupt enabled
    UCSR0C |= (1 << UCSZ01);// | (1 << UCSZ00);    // Set frame: 8data, 1 stp
    /*Set baud rate */
    UBRR0H = (( MYUBRR ) >> 8);
    UBRR0L = MYUBRR;
    UCSR0B |= (1 << RXCIE0);
    sei();
    while(1)
        if( ReceivedChar == 'C' || ReceivedChar == 'c'){
            PORTB |= (1<<PORTB5);
            _delay_ms(500);
        PORTB = 0x00;
        _delay_ms(500);
        PORTB = 0xFF;
        _delay_ms(500);
        // Main loop
ISR (USART0_RX_vect , ISR_BLOCK)
    ReceivedChar = UDR0;
    UDR0 = ReceivedChar;
    //sei();
Above is my code but my Interrupts not working as I intended
Dear milan,
Thank you for the reply but I think it is not relevant to Atmega2560 and I don't have a "USART_RXC_vect" & instead
I have "USART_RX_vect " for atmel studio.
Do you know a proper way to debug it so I could find the issue.
Are you using AVR Studio with WinAVR or Atmel Studio with gcc ?
I made a working code for Mega2560 at 16 MHz Clock. USART0 is used. Tested in Proteus 8.1. See if it works in hardware.
  • Atmel Studio 6.2 Projects.rar
