RuneHansen
Junior Member level 1
- Joined
- Mar 3, 2012
- Messages
- 18
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,293
- Location
- Denmark, Sjælland, Kalundborg
- Activity points
- 1,398
hey all.
i have a problem with a Uart code i have made in MikroC. i have tryed many things, but cant make it work :I
i want to send a text command via the Uart and then the Chip lights up some certain leds, but i cant light 2 leds up at once and turn them off as i want to because the loop just keep following its path and i dont know what im doing worng?
ps: im from Denmark- it explains my grammar and spelling
Here is the code
can some of you help me??
Thanks!
And it is also my first post on this forum
so.. yes.. im a newbit
Here is the code
void main() {
UART1_Init(9600); // konfiguration af UART modulet til 9600 bps.
Delay_ms(100); // Vendt på UART modulet til at blive stabilt.
UART1_Write_Text("ATMEGA2560 RESET"); // Under reset = send DATA.
UART1_Write(13);UART1_Write(10);
DDL7_bit = 1; // Sæt PORTL7 til at være digitale Udgange.
DDL6_bit = 1; // Sæt PORTL6 til at være digitale Udgange.
do {
if (UART1_Data_Ready() == 0) { // Hvis data er modtaget...
UART1_Read_Text("PL7 = ON", "PORTL_PL7_ON", 255); // Læs den modtaget data indtil "--" er fundet...
UART1_Write_Text("PL7 = ON"); // Send (DATA) tilbage.
PORTL = 0x80;
UART1_Read_Text("PL7 = OFF", "PORTL_PL7_OFF", 255); // Læs den modtaget data indtil "--" er fundet...
UART1_Write_Text("PL7 = OFF"); // Send (DATA) tilbage.
PORTL = 0x00;
UART1_Read_Text("PL6 = ON", "PORTL_PL6_ON", 255); // Læs den modtaget data indtil "--" er fundet...
UART1_Write_Text("PL6 = ON"); // Send (DATA) tilbage.
PORTL = 0x40;
UART1_Read_Text("PL6 = OFF", "PORTL_PL6_OFF", 255); // Læs den modtaget data indtil "--" er fundet...
UART1_Write_Text("PL6 = OFF"); // Send (DATA) tilbage.
PORTL = 0x00;
}while(1);
Thanks!
