[SOLVED] atmega16a runs on 1Mhz even with any crystal
prafful
Member level 2
Rajkot, India
Hello all,
I am making some programs in ATMEGA16A with bascom-avr. when i put delay for 1Sec it takes much(8sec) delay with 8Mhz and (16sec) with 16Mhz crystal.
After some time i have note that its by default working on 1Mhz clock. when i have remove crystal its also working on 1Mhz.
I can't understand. now its not working on 8Mhz even with crystal. its working on 1Mhz.
can anybody please explain???
-thanking you.. :roll:
The Atmega16 has an internal oscillator, its default is 1mhz so expect it is running on that.
It will ignore any crystal you have connected until you change your code/fuses to match - see the datasheet for all the options - the internal osc will run up to 8mhz so might as well use that, unless 16mhz is essential
Reactions: prafful
    prafful
hi,
i have purchased the new ATMEGA16A its come with 1Mhz default (internal RC oscillator).
hbyte -99
lbyte -E1..
i want to run this with 8Mhz or 16Mhz external crystal.
can anybody please give me fuse bytes for this both settings.
