[SOLVED] atmega16a bascom counter not work
prafful
Member level 2
Rajkot, India
hi.
i want to count external pulse for my atmega16A.
here is my code
$regfile = "m16def.dat"
$crystal = 8000000
Const Tick = 10
Dim Y As Byte
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Porta.4 , Db5 = Porta.5 , Db6 = Porta.6 , Db7 = Porta.7
Config Lcdpin = Pin , E = Porta.2 , Rs = Porta.0
Config Lcdmode = Port
Config Timer0 = Counter , Prescale = 1 , Edge = Rising
Load Timer0 , Tick
On Timer0 My_isr
Enable Timer0
Enable Interrupts
Display On
Lcd "Prafful Da Vinci"
Waitms 500
Do
Lowerline
Lcd "count" ; Timer0
Waitms 500
Cls
Loop
End
My_isr:
Load Timer0 , Tick
Y = Y + 1
Lcd Y
Return
i m giving 4 hz pulse form 555 timer circuit to my controller.
but after all, lcd only displaying TIMER0 value on lowerline.
it is not counting any external pulse.
what to do???
if there's no problem, counted value will be updated every 500 ms as the delay. but i usually found TCCR0 value was not fill exactly as we need. On your program, the value of TCCR0 will be &H01, but we need &H06 (maybe it's a bug of BASCOM). This &H01 means you set timer0 as timer with no presclaer. That's why you never see first line, because interrupt service called everytime when this timer overflow. Try replace Config Timer0 .... with "Tccr0=6".
Thanks a lot ARCH...
its a amazing suggestion i will try it soon on my mcu and tell you the result. hope it will work.
and by the way when i have look in simulation for tccr0 in above program it shows tccr0=h08 not h01.
Dear arch... thanks for suggestion.. i have tried with TCCR=H06 but still not showing any output.
$crystal = 8000000
Const Tick = 10
Dim Y As Byte
Config Lcd = 16 * 2
Tccr0 = 6
Reset Ddrb.0
Load Timer0 , Tick
On Timer0 My_isr
Enable Timer0
Enable Interrupts
Display On
Waitms 500
Do
Lowerline
Lcd "count=" ; Timer0
Waitms 500
Cls
Loop
End
My_isr:
Load Timer0 , Tick
Y = Y + 1
Lcd Y
Return
Ok, try this :
Code Basic4GL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
$crystal = 8000000
Const Tick = 10
Dim Y As Byte
Config Lcd = 16 * 2
Tccr0 = 6
Reset Ddrb.0
Ddrc = &HFF    'we use port C to check real value of timer
Load Timer0 , Tick
On Timer0 My_isr
Enable Timer0
Enable Interrupts
Display On
Upperline
Waitms 500
Do
Lowerline
PortC = Timer0
Waitms 500
Loop
End
My_isr:
Load Timer0 , Tick
Y = Y + 1
UpperLine
Lcd Y
Return
