ATMEGA128 programming problem
awaisaamir
Newbie level 6
Rawalpindi, Pakistan
hy
i recently start working with ATmega128 , i program it but i cant get output but in proteus it show output. i use avr studio 6
i post code here
#include <avr/io.h>
int main(void)
	DDRD=0xFF;
    while(1)
        //TODO:: Please write your application code
		PORTD=0xF0;
thanks.
I don't see anything wrong with the code, it sets PORTD as output ad then sets bits 7-6-5-4 to high.
What does proteus simulation show?
Have you loaded the hex/elf file correctly to the proteus mcu model?
EDIT: ok, you actually said hardware problem so I have no idea what can be wrong in order to make this not work.
If it was a clock problem you wouldn't be able to program the device.
hi
you r getting problem in proteus or in hardware?
He is not getting o/p in hardware.
Reactions: ismbn
    ismbn
mega128 has three grounds and two Vcc and one AVcc , have you connected them all to power supply?
yes i connected all supply , controller is on but only JTAG pins are on HIGH state :(
this code is ok ??
what fuse setting should be for this code i am using 12 MHZ crystal oscillator
