agreatstar
Junior Member level 2
I have a zigbee connected to atmega16. I am using 12V lead-acid battery to power the controller. Sometimes when I power up, the Zigbee TX line is contnuously turned on and xbee doesnt work. But if I remove the battery and replug it, everything works fine. Problem occurs randomly, almost 4 times in 10 runs. One thing that I dout is Atmega reset coz on my board, reset is directly connected to VCC (no external power-up reset circuit is present and brown-out detection is disabled). Can that be the problem?
