alexhugo
Junior Member level 3
I am using ATMEGA48. I have following peoblems:
1- Whatever I do, I must have external reset circuit. I set the BODLEVEL fuses to be 4.3 volts hoping that BOD will reset my microcontroller when VCC starts going up but it doesn't work that way. I even programmed the RSTDISBL fuse but that doesn't help either.
2- I don't know why touching the capacitor (or the reset pin itself) that is used for reset, hangs the micro. I am using 10K resistor and 100u cap for reset circuit. Please don't say that I should not touch the reset signal. I know that but this means that's very sensitive to noise. Isn't it?
3- When micro freezes because of the problem in item 2, watchdog timer doesn't reset the chip. Watchdog timer works in other times. For example when I remove the wdr (watch dog reset) command, or I don't call the place that has wdr, I see that my micro gets reset but freezing because of touching the capacitor of the reset circuit is not reset by watch dog timer.
Thanks in advance
Alex
Thanks in advance
Alex
