atmega 16 vs at89c2051
aadarsh
Newbie level 6
india
Hiii friends,
i want to replace at89c2051 with atmega 16 in my circuit ,is this possible? If yes plzzz do let me know as soon as possible....
I don't understand what you are asking exactly.
If you want to use mega16 in place of at89c2051 in an existing pcb then it can't be done because the don't match in pin count or pinout.
If you will make a new connection scheme and correct the code as well to be able to run in the new mcu then sure you can.
Alex
thanks a lot sir.....
can u help me on buliding new schematic with atmega16 replacing tht having at89c2051?
Will you be able to successfully transfer the code to the new device?
The schematic shouldn't be hard, give it a try and post here the results.
Alex
I think you cannot replace a 20-pin IC with a 40-pin IC,can you..???
If you want to use Atmega16 try building up your system according to its requirements...
