elcielo
Full Member level 6
linux 2.6.13 at91_set_gpio_direction include
2.6.13 patch for AT91RM9200 (01/09/2005)
AT91RM9200 support updated for 2.6.13.
- USB Host: Do not take controller out of reset in at91_start_hc() [Eric Benard]
- Moved at91_spi.h to include/asm-arm/arch-at91rm9200/
- Changes proposed by Alexey Dobriyan:
+ Space before star, when using pointers.
+ Order in structures
+ C99-style initializers (spidev, dataflash, nand, i2c)
+ Replace BYTE_SWAP4() with swab32() [David Brownell]
- PCMCIA: Fixed order of calls in at91_cf_remove() [Steven Scholz]
- GPIO: at91_set_gpio_direction() replaced with at91_set_gpio_input() and at91_set_gpio_output().
- Ethernet: Converted to ethtool_ops [Eric Benard]
- Fix definition of __io() and __mem_pci [Steven Scholz]
- Support for KwikByte's KB9202 board [kb9200_dev <at> kwikbyte.com]
- Support for NAND flash with 2K page-sizes (eg Samsung K9F1G08U0A) [Zhang Qian]
- at91rm9200_irq_type() can set edge/level-triggering for FIQ [Karl Olsen]
- I2C: Set adapter.class to I2C_CLASS_HWMON [Mike Crowe]
- USB Device: USB_GADGET_SELECTED should be selected in Kconfig [Tom Rathbone]
- Definition of AT91C_SMC2_DBW was incorrect [Steven Scholz]
- Serial: uart_handle_dcd_change() and uart_handle_cts_change() already increment the port->icount counters [Russell King]
- Ethernet: Support for Altima AC101L Ethernet PHY [Andrew Lewis]
- Ethernet: Don't run MDIO interface faster than IEEE maximum of 2.5 MHz. Also removed special handling of the Intel, Realtek, and Broadcom PHY's [Karl Olsen]
- DataFlash: Different partitioning for 2M, 4M and 8M devices, taking into account the sector boundaries.
- Serial: Select between ttySx and ttyATx for the device names of the internal serial ports. [Karl Olsen]
