AT90S1200-based Logicanalyzer
arrest
Newbie level 5
Germany
lola logic analyzer
with I2C-Sniffer.
at90s1200
Having downloaded the files, it looks very impessive and promising.
Have you built the unit?
Also, do you have more info of its origin, like author etc.
Regards,
sda
projects at90s1200
Go to **broken link removed** and after login look into the Academy for project id 47
Arno Hinrichs is the author of the logic analyzer. You can PM in avrfreaks forum.
Filename: LoLA.zip
Revision: 1.0
Published: Jan 2, 2006
Filesize: 697.73 KB
at90s1200 based projects
Thank you for the info.
One point though, the 6116 ram used, is a very hard item to get hold of, the maxim DS 1220 looks like a compatable device.
Your remarks?
regards
sda
i2c sniff 2313
Yes, it's direct compatible.
logic analyzer hinrichs
Thank you,
After asking around here in greece, I have managed to source the 6116 but the micro is discontinued.
I have one which is rated at 4Mhz, which is unsuitable, unless it will work overclocked, but I think I'll compile the asm for a tiny2313 which is pin compatable.
Thanks again
regards
sda
at90s1200 projects
hi sda, did you made this logic analyzer LOLA?
I want make it but I would like to use a attiny2313 just burn with original HEX file, do you think its work?
regards
aldevan
at90s1200 i2c
Yes have constructed the unit, and works great.
You will have to use a different hex file for the 2313.
If you need further help, don't hesitate to contact me.
cheers
sda
lola at90s1200
sda did you updated this to attiny2313, but did you made modifications to use UART? the pin TX and RX is same original lola diagram schematic? or you are using tx and rx from 2313 pins?
arno hinrichs lola
My variant of PCB for LoLa
lola logic-analyzer
learn more about logicanalyzer
+schematic +logicanalyzer
Do you have the protel pcb files? Can you upload them here?
