at89c52 how to create function for saving memory space
numair_noor
Member level 2
hi, i have tried to create a program for password based security with lcd display.
i have used mikroc. it has built in lcd program for lcd commands. but it takes too much space every time i write lcd out command in my program.
my question:
1. i need a function which can show the output on lcd. using built in lcd_out command
for example:
void show();
void show(i)
LCD_OUT(2,1,ARRAY)
i++
so i can just put the function SHOW(); at anywhere and call this function saving my memory space. otherwise i run out of memory. my code is not finished yet. but i need to finish it as quickly as possible.
any assistance from any one is so welcome. thanks so much in advance.:)
CODE:
bit pass_flag;
 char kp[4];
 char amir[4]={'a','m','i','r'},asim[4]={'a','s','i','m'};//,asad[4]={'a','s','a','d'};//saeed[5]={'s','a','e','e','d'};
unsigned char i=0,j=0;
void name();
void Lcd_Init();
// Lcd module connections
sbit LCD_RS at P0_0_bit;
sbit LCD_EN at P0_1_bit;
sbit LCD_D4 at P0_2_bit;
sbit LCD_D5 at P0_3_bit;
sbit LCD_D6 at P0_4_bit;
sbit LCD_D7 at P0_5_bit;
// End Lcd module connections
void main()
//again:
p1=0x00;
p2=0x00;
p3=0x00;
//p0.B6=0;
//p0.b7=0;
Lcd_Init();                              // Initialize Lcd
Lcd_Cmd(_LCD_CLEAR);                     // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF);                // Cursor off
LCD_OUT(1,1,"enter name");
delay_ms(500);
  while(1)
pass_flag=0;
////////push buttons FUNCTIONS START////////////////
name();//enter name
//reg();//ENTER REGISTERATION NUMBER
void name()         //function for registeration number
         for(i=0;i<4;i++)
         while( p1==0x00 && (p3.b0!=1) && (p3.b1!=1) && (p3.b2!=1) && (p3.b3!=1) && (p3.b4!=1) && (p3.b5!=1) && (p3.b6!=1) && (p3.b7!=1)  )//; //wait for any key to be pressed        (p2.b0!=1) && (p2.b1!=1) && (p2.b2!=1) && (p2.b3!=1) && (p2.b4!=1) && (p2.b5!=1) && (p2.b6!=1) && (p2.b7!=1)
          //////////////////new start/////////////////
          if(p2.b0==1) //for a
                 //f=='0';
                 kp[i]='a';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"a"); //LCD OUT =a
                 while(p2.b0!=0);
         else if(p2.b1==1)   //for b
                 //f=='0';
                 kp[i]='b';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"b"); //LCD OUT =0
                 while(p2.b1!=0);
         else if(p2.b2==1)   //for d
                 //f=='0';
                 kp[i]='d';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"d"); //LCD OUT =0
                 while(p2.b2!=0);
         else if(p2.b3==1) //for l
                 //f=='0';
                 kp[i]='e';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"e"); //LCD OUT =0
                 while(p2.b3!=0);
         else if(p2.b4==1)   //for m
                 //f=='0';
                 kp[i]='i';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"i"); //LCD OUT =0
                 while(p2.b4!=0);
         else if(p2.b5==1)   //for m
                 //f=='0';
                 kp[i]='m';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"m"); //LCD OUT =0
                 while(p2.b5!=0);
         else if(p2.b6==1)   ///for n
                 //f=='0';
                 kp[i]='n';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"n"); //LCD OUT =0
                 while(p2.b6!=0);
         else if(p2.b7==1)   //////for r
                 //f=='0';
                 kp[i]='r';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"r"); //LCD OUT =0
                 while(p2.b7!=0);
        else if(p3.b7==1)   ////for s
                 //f=='0';
                 kp[i]='s';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"s"); //LCD OUT =0
                 while(p3.b7!=0);
        else if(p3.b6==1)   ////for t
                 //f=='0';
                 kp[i]='t';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"t"); //LCD OUT =0
                 while(p3.b6!=0);
          else if(p1.b0==1)    ////for 0
                 //f=='0';
                 kp[i]='0';       //put 0 in digit[i]
                 Lcd_Out(2,i+1,"0"); //LCD OUT =0
                 while(p1.b0!=0);
          else if(p1.b1==1)        //for 1
                 kp[i]='1';    //put 1 in digit[i]
                 LCD_OUT(2,i+1,"1");  //LCD OUT =1
                 while(p1.b1!=0);
          else if(p1.b2==1)        //for 2
                 //f=='2';
                 kp[i]='2';     //put 2 in digit[i]
                 LCD_OUT(2,i+1,"2");  //LCD OUT =2
                 while(p1.b2!=0);
          else if(p1.b3==1)        //for 3
                 kp[i]='3';        //put 3 in digit[i]
                 LCD_OUT(2,i+1,"3");//LCD OUT =3
                 while(p1.b3!=0);
          else if(p1.b4==1)        //for 4
                 kp[i]='4'; //put 4 in digit[i]
                 LCD_OUT(2,i+1,"4");//LCD OUT =4
                 while(p1.b4!=0);
          else if(p1.b5==1)        //for 5
                 kp[i]='5';//put 5 in digit[i]
                 LCD_OUT(2,i+1,"5");//LCD OUT =5
                 while(p1.b5!=0);
          else if(p1.b6==1) ///for 6
                 kp[i]='6';  //put 6 in digit[i]
                 LCD_OUT(2,i+1,"6");//LCD OUT =6
                 while(p1.b6!=0);
          else if(p1.b7==1)        //for 7
                 kp[i]='7';   //put 7 in digit[i]
                 LCD_OUT(2,i+1,"7");//LCD OUT =7
                 while(p1.b7!=0);
          else if(p3.b0==1) //for 8
                 //f=='8';
                 kp[i]='8';    //put 8 in digit[i]
                 LCD_OUT(2,i+1,"8");//LCD OUT =8
                 while(p3.b0!=0);
          else if(p3.b1==1)        //for 9
                 //f='9';
                 kp[i]='9';   //put 9 in digit[i]
                 LCD_OUT(2,i+1,"9");//LCD OUT =9
                 while(p3.b1!=0);
          else if(p3.b2==1) //////////for *
                 //f=='8';
                 kp[i]='*';    //put 8 in digit[i]
                 LCD_OUT(2,i+1,"*");//LCD OUT =8
                 while(p3.b0!=0);
          else if(p3.b3==1)    /////for #
                 //f='9';
                 kp[i]='#';   //put 9 in digit[i]
                 LCD_OUT(2,i+1,"#");//LCD OUT =9
                 while(p3.b3!=0);
           /////////////////////name end before comparison/////////////
//COMPARISON STARTING FROM HERE
        // if(pass_flag==0)
                    if( ( (kp[0]==amir[0])  &&  ( kp[1]==amir[1])   &&   ( kp[2]==amir[2]) )  ||   (  (kp[0]==asim[0])  &&  ( kp[1]==asim[1])   &&   ( kp[2]==asim[2]) )  )
                    //delay_ms(1000);
                    //delay_ms(1000);
                    Lcd_Out(1,4,"ENTER PASSWORD");
                    pass_flag=1;
                   // name();
                    //else
         //else if(name_flag==1&&pass_flag==1)
             //       if(     (  (kp[0]==nasir[0])  &&  ( kp[1]==nasir[1])   &&   ( kp[2]==nasir[2]) )  ||      (  (kp[0]==basit[0])  &&  ( kp[1]==basit[1])   &&   ( kp[2]==basit[2]) )   ||   (  (kp[0]==imran[0])  &&  ( kp[1]==imran[1])   &&   ( kp[2]==imran[2]) )   ||   (  (kp[0]==saeed[0])  &&  ( kp[1]==saeed[1])   &&   ( kp[2]==saeed[2]) ) )
                 //   Lcd_Cmd(_LCD_CLEAR);
 //                   Lcd_Out(2,5,"****");
   //                 delay_ms(2000);
       //             Lcd_Out(1,4,"WELCOME");
         //           pass_flag=0;
  //       else if(name_flag==1 && pass_flag==1)
I SHALL KEEP U UPDATED IF U WANT TO KNOW ANYTHING
I NEED TO CHANGE THIS PART:
                 //f='9';
                 while(p3.b3!=0);
TO LIKE THIS:
                 //f='9';
                 show(char i,kp[i]);
                 while(p3.b3!=0);
etc.
