[51] AT89C2051 Works in Proteus But it not works in Hardware.
yuvarajbe
Newbie level 5
hello ,
i am working on AT89C2051, i am trying to make a simple code as a start up for my full project .
i wrote i code just to switch the led on at P3^1 , it works in proteus but it is not working in real hardware .
also i tried to wrote a simple code in c language using Keil platform, and it burner by Willar Programmer. Here with I attached my code
anyone can give a help to solve the problem .
code:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
#include <at892051.h>
/*function for delay of 1 sec*/
sbit p3=P3^1;
void delay()
      unsigned int x;
      for(x=0;x<33000;x++);
main()
   int cnt = 0;
      for (;;)
      p3=1;
           delay();
            p3=0;
           delay();
KlausST
Super Moderator
Staff member
it works in proteus
.. this tells me the code does work.
So what about your hardware?
Klaus
yuvarajbe
Newbie level 5
In Hardware nothing happened.its idle mode.I have one more doubt.
I am using IDE Keil uvision 2 its Evaluation version.For this any problem occur???
saswat
Junior Member level 2
No problem in using IDE Keil uvision 2 Evaluation version. The Evaluation version is capable to handle the code size up to 2 kb and your code is less than this. Have you made your own hardware or you are using EVK board (or development board) ??.
yuvarajbe
Newbie level 5
Hi
Its my Own hardware. Connection shown below image.I connect port 3.1 instead of led pin in imagesch1.png
saswat
What is the resistance value of the resistor which is connected with led?
yuvarajbe
Newbie level 5
Resistance Value is 330ohm. But i directly measured the pin3.1 through multimeter. there is no response While i give high or low by coding.
Okada
Banned
Maybe you have compiled for Debug mode instead of release mode.
yuvarajbe
Newbie level 5
In the debug mode, debugger use .obj files, and generate hex file in the state of release mode.
I cant get what u said?
saswat
Just add one pull up resistor of 10K fromVcc to P3.1 and check by giving logic high and low!!
