May 31, 2016 #1 Y yanuma Newbie level 5 Joined Jun 25, 2015 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 24 at89c2051 p3.7 end press the button that connected the port p1.6 and I want to leave off exit 10 seconds apart in the port p1.7 Arlie
May 31, 2016 #2 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,287 Helped 4,874 Reputation 9,769 Reaction score 5,569 Trophy points 1,393 Activity points 169,331 Hi, To me it is not clear what you need. Maybe a picture could help. Klaus
May 31, 2016 #3 Y yanuma Newbie level 5 Joined Jun 25, 2015 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 24 Code: #include<reg.51.c> #include<delay.> sbit buton_PIN=3^7 sbit led_PIN =1^6 sbit ledd_PIN=1^7 void() { basla: if(butonpin3_7: ledpin1_6high: delay_ms_50 : leddpin1_6LOW: THEN(ledpin1_7high: delay_ms50: leddpin1_7LOW: goto basla: } I wrote a code like this - - - Updated - - - [CODE Last edited: May 31, 2016
May 31, 2016 #4 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,287 Helped 4,874 Reputation 9,769 Reaction score 5,569 Trophy points 1,393 Activity points 169,331 Hi, Please be more descriptive. * Where do you need help? * What do you expect? * What happens instead? Klaus
May 31, 2016 #5 Y yanuma Newbie level 5 Joined Jun 25, 2015 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 24 KlausST hi pic. as I have written in this integrated circuit in the same basic language but I couldn't do it in C language - - - Updated - - - where is the mistake in this code
May 31, 2016 #6 M Ma3ix Member level 2 Joined Dec 17, 2015 Messages 43 Helped 0 Reputation 0 Reaction score 0 Trophy points 6 Activity points 375 try simulation without delay function,subroutine and for one led pin
May 31, 2016 #7 Y yanuma Newbie level 5 Joined Jun 25, 2015 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 24 Is there any problem in code that i have written? - - - Updated - - - at89c2051 When I push and pull the button in p3.7, p1.7 will out for 10 seconds after that p1.6 will out and the programme will return the begining.
May 31, 2016 #8 xenos Full Member level 4 Joined May 9, 2015 Messages 212 Helped 82 Reputation 164 Reaction score 81 Trophy points 28 Location 127.0.0.1 Activity points 1,182 You have not post C code. Almost every line has syntax errors. You should keep using basic, or you will neer to dive in C study. Try K&R (Kernigham & Richie bible book: the C programming language) or other tutorials
