AT89C2051 code problem
Arrowspace
Banned
My code is not working.
//#include <REG2051.H>
//#include <REGX52.H>
//#include<reg51.h>
//#include<AT892051.H>
//#include<AT89x51.h>
#include <reg2051.h>
void T1M1Delay(void);
void delay(unsigned int msec ); // Time delay function
  sbit input1 = P3^2;
  sbit input2 = P3^7;
  sbit Relay = P1^0;
  sbit mosfet = P3^4;
void main()
P3_2 = 1;
P3_3 = 1;
P1_0 = 0;
P1_7 = 0;
 input1 = 1;
 input2 = 0;
 Relay = 0;
 mosfet = 0;
//delay(2);
while(1)
T1M1Delay() ;
T1M1Delay() ;
T1M1Delay() ;
T1M1Delay() ;
T1M1Delay() ;
T1M1Delay() ;
T1M1Delay() ;
T1M1Delay() ;
  input2=0;
Relay = 0;
mosfet = 0;
delay(2);
void delay(unsigned int msec ) // Time delay function
int i ,j ;
for(i=0;i<msec;i++)
  for(j=0; j<1275; j++);
  TMOD=0x10;
  TL1=0xFE;
  TH1=0x0A5;
  TR1=1;
  while(TF1==0);
  TR1=0;
  TF1=0;
I am trying to glow LED on my board , which is not working is connected on pin P3.7
This code below seemed to work OK. Tested with LED's on outputs. LED's on when PINs = 0;
#define input1 P3_2   //   sbit input1 = P3^2;
#define input2 P3_7   //   sbit input2 = P3^7;
#define Relay P1_0    //   sbit Relay = P1^0;
#define mosfet P3_4   //   sbit mosfet = P3^4;
void main()
   input1 = 1;     //   PORT3 PIN 2 = 1
   input2 = 0;     //   PORT3 PIN 7 = 0
   Relay  = 0;     //   PORT1 PIN 0 = 0
   mosfet = 0;     //  PORT3 PIN 4 = 0
   while(1)        // while forever
      input2 = 0;  // keep everything the same as above
      Relay  = 0;
      mosfet = 0;
      delay(2);    // wait before keeping everything the same again
   int i ,j ;
   for( i = 0; i < msec; i++)
      for( j = 0; j < 1275; j++);
this code is also not working
Pls find circuit
According to the schematic you've posted, it appears the value of the current limiting resistor, ~2KΩ, is too high and does not allow sufficient current to light the LED.
If your Vcc = 5V, required current I = 10mA, LED forward voltage drop Vf ~ 2V, then the current limiting resistor, R ~ 300Ω/330Ω.
BigDog
