AT45DB041 Keil Code for using with LPC2103
pasicr
Advanced Member level 1
Macedonia
Hi for All, do you someone have KEIL lib (c code) for serial flash AT45DB041 for using with LPC2103,
regards
it would be quite unusual for someone to have exactly the same code for your exact configuration.
you are far better served if you start coding it yourself, hopefully from code on like devices.
those memory chips are highly similar and quite easy to code.
    pasicr
