at command help for aubtm-20 bluetooth module!!!!!!!!!
kunal123
mumbai
hello,
can anyone post a circuit screenshot which tells how i can send AT commands to aubtm-20 bluetooth module from serial port & also screenshot of hyperterinal which shows AT commands & odule responce
srknthmk
Newbie level 3
hi friends,
i am facing the same problem. please post details for this thread
thank you
srknthmk
Newbie level 3
hi kunal,
i am having the aubtm 20 command set. but whenever i try to send a command (eg: 'LLL'), i didn't get any response from the module (eg: 'OK').
can you please help me by providing the step by step instructions??? it 'll be very helpful.
thank you for responding
hi kunal,
kunal123
mumbai
hi kunal,
hi kunal,
hi srknthmk,
u want to aubtm-20 module test using hyperterminal or using microcontroller, i had some success in aubtm-20 module test using hyperterminal, when u turn ON aubtm-20 module & it is connected to PC using serial interface it gives responce as OK, if u not get this responce check aubtm-20 module power supply connection it should be 3.3v not more than that
