[SOLVED] "AT+CIPSEND" in wavecom AT-COMMAND
saesaria
Member level 1
Member level 1
Indonesia
I want to send a http request using WAVECOM AT-command, anyone knows what the AT Command?
thanks
all the supported AT commands are found in the supplied AT Command set pdf
if you want to establish a connection you should first make a gprs connection using your service provider settings
you should know (APN , Username , Password)
when an internet connection is established you sould sent a simple ping request then advance to an HTTP request
regards
regards
I already set the APN, username, and password here on my previous thread
https://www.edaboard.com/threads/217319/. I just difficult to find similar AT+CIPSEND in wavecom AT-command set.
Then to PING as you asked, I tried
AT+WIPPING="www.google.com"
OK
+WIPPING: 1,0,0
the respond "+WIPPING: 1,0,0" means that the PING request is failed "timeout expired".
can you help me then?
thanks.
