iamlearning
Junior Member level 1
Hi!
Could anyone please mention up to which subversion of Assura32 is compatible with Cadence IC612? I mean USR1, USR2 etc.
I installed Assura41 and tried to use it together with the IC612, but it generated a warning in the CIW, like:
*WARNING* Failed to load context file '/vhome/eda/Assura41/bin/32bit/etc/context/6.1.2/sna.cxt'.
Even the directory does not exist there! Again, when I tried DRC, it halted with the message: Waiting for license validation for . in the DRC log file. Later, going through the release notes, I came to know that, Assura41 is qualified with IC614 only and that, it uses new licensing technique- FLEXlm v10.80. That is why, my license server needed to be upgraded.
So, I think I would better use Assura32, but not sure about the subversion. Anyone please check if I miss something here.
Thank You,
Reagards.
Thank You,
Reagards.
