pcca
Junior Member level 3
Hello,
I am with problems to run Assura and DRC and LVS verifications. The Design kit that is being used is the IBM8rf-DM 130n.
Before to start the design some configurations to setup the DK were done (http://ece.osu.edu/computing-resources/software-packages/cadence).
To test Assura and DRC analysis I designed a simple inverter.
Running DRC analysis the following error was reported:
"Failed to build VDB. Cannot submit DRC Run"
I spent sometime looking for a solution for this issue but i did not found any that solved my problem.
Running LVS the error reported is: "The extracted rule file was not found"
But the extracted rule that it is set is: MY_DIR/IBM_PDK/cmrf8sf/V1.8.0.4DM/Assura/LVS/extract323.rul
When I change the extracted rule for this: ........../Assura/QRC/41/extract.rul it works...
I hope that someone can help me.
Regards.
Regards.
