Assertion based verification
karthikeyan
Newbie level 6
What u mean by Assertion Based Verification and usages? and what is different b/w 0-IN & OVL Assertions?
Is it possible to see a assertion coverages??
clarify the doubts to me.......
Thanx in advance
zhangpengyu
Full Member level 3
Hi
I think assertion verification is insert event in hdl code,then tools can collect the information from the code.
zhpy
AlexWan
Full Member level 5
pls reference:
hxxp://www.verificationlib.org
good luck!
xworld2008
Full Member level 4
when you do verification, you can use assert to warn the data have error, this can reduce you
debug time.
karthikeyan
Newbie level 6
Is it possible to see a Assertion Coverages???
AlexWan
Full Member level 5
I think we get the coverage of assertion with the assertion report.
During verification with assertion, the assertion function is used by normal RTL code. If the assertion is executed, the coverage rate will be counted.
AlexWan
Full Member level 5
Certainly, I think we don't need the assertion coverage.
For this, we may use the asseration in the testbench, not RTL code. With the hierachical calling, we call the assertion module in the TB.
Other way, use assertion with the specified comments by simulation tools. During verification, the coverage tool will dont counte the hit rate of assertion statements.
Good luck
karthikeyan
Newbie level 6
What is different between OVL,OVA and 0IN based assertions?
AlexWan
Full Member level 5
Sorry!
Can you spell the OVA and OIN?
I only know about and use the OVL.
karthikeyan
Newbie level 6
OVA : Open Vera Assertions(synopsys)
0(zero)IN: company name.,0IN based Assertion Based verification.
vale
It seems that synopsys is pushing up systemverilog to substitute "verilog + vera" in future. The assertion based verification is one of the key features of SV. IMHO, ABV is an useful method to aid verification, but it can't solve all problems.
nagraj
Member level 2
AlexWan said:
Yes, The tools nowadays support assertion based coverage reports which will give information regarding number of assertion being fired ..etc.
Good luck
AH Ling
Newbie level 5
ABV is an verification methodology that can be classified into three approaches:
1. functional coverage: this is not code coverage but it is to verify completeness of you test against specification. if you get 100%, means all your function are met according to your spec.
2. constrained-random test: constrained test is to simulate specific scenario and random here refer to randomize your inputs to expose corner cases
3. coverage-driven verification: combines both 2 aprroaches above...to eliminate repetitive test of same scenario that is correct...
System verilog is the HDL that could support ABV....
