Assembly Language question
milvapp
Member level 5
chania greece
In terms of hardware is there any possible way to implement a branch instruction (beq,bne etc)
without using flags?
For example BEQ R1 R2 label if R1=R2 branches to label.
I substract R1-R2 at the ALU but how can I check that the result is zero ?
P.S. Please dont tell me compare it with a dummy register containing the value 0
because I conclude to the same point :p
Thank you in advance.
KerimF
Syria
Don't you know the answer? :)
jpanhalt
Advanced Member level 3
Look up the assembler pseudo-mnemonic BZ or used BSTFC status,2>goto... Personally, I think writing it out , rather than using the pseudo-mnemonic is better. Of course, after the subtraction that yields zero.
John
