assembly language programming
lamiajoyee
what is the difference between the following two codes? can anyone tell me?
ORIGIN 1000
DATAWORD 300
and
MOVE #300,1000
srizbf
Advanced Member level 5
no difference.
1st one initialise 300 at address 1000 by assembler.
2nd one same initialisation by processor.
    lamiajoyee
lamiajoyee
i know there is no difference but the timing is what matters.could you please tell me when 300 is stored in location 1000 for the two separate occassions?
srizbf
after assembling the codes shown ,
1st method starts the program with 300 at loc 1000.
whereas in second method , it is at that time when move is executed.
until then loc 1000 content is not known
    lamiajoyee
lamiajoyee
here is my problem:
register R5 is used to point the top of the stack.write sequence instruction to pop the top two items off the stack, add them and push the result onto the stack. also copy the fifth item from the top into register R3 and remove the top ten items from the stack.
here i only know two instrctions.how can i implement the above problem using these and more instructions?please help me.
 MOVE item,-(SP)
MOVE (SP)+,item
srizbf
an incrementing or decrementing stack type ?
any pop /push instrctions available?
lamiajoyee
they have asked me to use index,auto increment and auto decrement mode
srizbf
for increment type:
MOVE num1,-(SP)
MOVE num2 , -(SP)
add num1,num2
MOVE (SP)+ , num1
other parts . whether to get fifth item after adding and pushing to stack or get before .
not clear
Added after 2 minutes:
a 68000 book will give you the idea.
    lamiajoyee
amraldo
Egypt
The first is compile time (assemble time) initialization while the second is run time initialization.
Amr
    lamiajoyee
amraldo
Egypt
Which processor and assembler are you targeting?
Amr
lamiajoyee
im a total newbie.im studying 8085 computer architecture.so i actually dont the processor or assembler
srizbf
you can see the following for beginning with 8085 assmbler.
http://gnusim8085.sourceforge.net/doc/asm-guide.html
if you visit:
there are 8085 related materials on this page.
download the pdfs and read.
you will get the grip of 8085.
hope it helps you
