Assembly Language output from arm-elf-gcc
subdural
Junior Member level 1
Neutral Zone
arm-elf-gcc assember tutorial
Hi All,
I'm compile the example.c source code to arm-elf gcc compiler with successful output. Also, I try to compiler this source code using "arm-elf-gcc -S example.c" to get assembly language (instruction set) output. I manage to compile it with no erros but I cant see the output on Cygwin Shell. I need your help how to see or get the assembly language output?
Thank in advanced
arm-elf-gcc compiling to assembly code
I'm not familiar with that particular gcc compiler, but -S normally works fine. You don't see any error messages, and you don't get a file named example.s?
Try typing arm-elf-gcc --help to see if -S is listed in the available options. My gcc 3.4.2 says "compile only; do not assemble or link"
Try typing arm-elf-gcc --version to see the gcc version. Maybe someone here will know the problem.
    subdural
arm assembly language gcc
You can try with disassembly also
make a .elf file and then use
arm-elf-objdump -D elffile name > dump file name
use vi to view dump file
    subdural
