Assembly language help!!
INS-ANI
Full Member level 3
dup assembly language
Here is the problem statement:
>> WAP to take a string from user and then display it.
solution( what i have found till now)
.MODEL SMALL
.DATA
DISP1 DB 0DH,0AH,"Enter the desired string=",0DH,0AH,"$"
DISP2 DB 0DH,0AH,"The stored string is=",0DH,0AH,"$"
STRIP DB (?)
.CODE
        MOV AX,@DATA
        MOV DS,AX
        MOV AH,09H
        LEA DX,DISP1
        INT 21H
        MOV CL,07H
        LEA SI,STRIP
LOOP2:
        MOV AH,01H
        INT 21H
        MOV [SI],AL
        INC SI
        DEC CL
        JNZ LOOP2
        MOV AH,09H
        LEA DX,DISP2
        INT 21H
        MOV CL,07H
        LEA SI,STRIP
LOOP1:
        MOV AH,02H
        LEA DL,[SI]
        INT 21H
        INC SI
        DEC CL
        JNZ LOOP1
        MOV AH,4CH
        INT 21H
        END
the problem:
I am able to take input from user succesfully, but it is not displayed properly .
I request some experienced member to please help me out.
Also if possible, please advice me on troubleshooting process.
Thanks in advance.:)
Jayson
Full Member level 4
Brazil
assembly language db
Have you tried changing LEA DL,[SI] to MOV DL,[SI]
How is memory for STRIP allocated? Have you considered defining it as:
STRIP DB 00H,00H,00H,00H,00H,00H...
INS-ANI
Full Member level 3
mov si,offset str1
@jayson
NOT GOOD, When i use the syntax as adviced by you, i am experiencing an error in line 38 , that is
"LEA DL,[SI] "
Added after 5 minutes:
got it,
i changed the syntax to
STRIP DB 10 DUP(?)
and the line 38 to MOV DL,SI
and the code works..now need to verify which line had the error.
Added after 4 minutes:
Guys, please help me out why the correction works?
in line 38 i earlier tried LEA Dl,STRIP
but it didnt work.
similarly
STRIP DB DUP(?) doesn't work
why?
Jayson
Full Member level 4
Brazil
what is ah/ assembly language
At minimum LEA needs a 16-bit destination register to store the address, DL is an 8-bit register.
STRIP DB DUP(?) is invalid since the syntax for DUP is:
count DUP (initialvalue [[, initialvalue]]...)
INS-ANI
Full Member level 3
what is 0dh in assembly language
Thanks sir.
INS-ANI
Full Member level 3
dup (?) assembly language
Here is a program to take a string from user, then test how many times a given char occurs in the string.
.MODEL SMALL
.DATA
MSG1 DB 0DH,0AH,"ENTER THE STRING=",0DH,0AH,"$"
MSG2 DB 0DH,0AH,"ENTER THE CHARACTER TO BE SEARCHED=",0DH,0AH,"$"
MSG3 DB 0DH,0AH,"THE COUNT OF CHARACTER IS =",0DH,0AH,"$"
COUNT DB 01 DUP()
STR1 DB 10 DUP()
CHAR DB 01 DUP()
.CODE
          MOV AX,@DATA
          MOV DS,AX
          MOV ES,AX
          MOV AH,09H
          MOV DX,OFFSET MSG1
          INT 21H
          MOV CX,07H
          MOV SI,OFFSET STR1
LOOP1:    MOV AH,01H
          INT 21H
          MOV [SI],AL
          INC SI
          DEC CX
          JNZ LOOP1
          MOV AH,09H
          MOV DX,OFFSET MSG2
          INT 21H
          MOV SI,OFFSET CHAR
          MOV AH,01H
          INT 21H
          MOV [SI],AL
          MOV CX,07H
          MOV DI,OFFSET STR1
          XOR BL,BL
          MOV SI,OFFSET CHAR
          CLD
SCAN:
          MOV AL,[SI]
          SCASB
          JNZ NEXT1
          INC BL
NEXT1:
          INC SI
          DEC CL
          JNZ SCAN
          ADD BL,30H
          LEA SI,COUNT
          MOV [SI],BL
          MOV [SI],BL
          MOV AH,09H
          MOV DX,OFFSET MSG3
          INT 21H
          MOV AH,02H
          MOV DL,OFFSET COUNT
          INT 21H
          MOV AH,4CH
          INT 21H
          END
I was able to get the string from user, but i guess there's something wrong in the later part.
FvM
Super Moderator
Staff member
Bochum, Germany
assembly language dup
I don't see an error at first look. Trace execution in debug.
P.S.: I wonder why you are using pointers for simple variables. You could write e.g.
MOV Count,AL
as well.
INS-ANI
Full Member level 3
mov dl,[si]
i will try that.. thanks.
