hi..
i m doing my BE project.i m are using 8051 microcontroller.
i want assembly code for temperature sensor lm35 interfaced to 8051 and display on the lcd.and then to display on seven segment display.
plzz do help.its urgent..
thax.
yes.temperature sensed.
actually its not a led display.its a electromechanical display where the leds are replaced by the plastic segments controlled by the motors...
plz help..
you have to convert analog output to digital and for that you can use p1 port of 8051 and then interface
LCD to display the respective result, here is the program for that : **broken link removed**
or otherwise post a complete diagram including the connections of E.M.Display with 8051.
Firstly post your schematic . . . By the way you will require an adc0804 for converting analog value of lm 35 into digital , and also u will need an amplifier circuit between lm35 and adc , i hav recently prepared this mini project , tell me if you need any guidance
---------- Post added at 13:36 ---------- Previous post was at 13:22 ----------
hi..
thax.
