1. Why on the third draft of the array 4x1 has a different shape compared to the array of 2x1 or single element?
2. Why is the design of the 2x1 has the value return loss larger around-32 db compared to the draft 4x1?
should be on the design of the 4x1 has a power greater than 2x1.
Please help me answer the 2 questions above. If I can beg to be given references about an array of antenna theory. Thank you very much for the help.
Seeing different return loss numbers only means that the antennas have slightly different input impedance. The image might change completely with small variations of the matching network.
The most significant information is that the 4x1 array has larger bandwidth.
