ASK: Farfield approximation in CST MWS
eirp
Advanced Member level 1
Phase center
Hi all!
I'm just curious if it's possible to disable the farfield approximation in farfield display (I know this sentence is a bit misleading
I mean the line
Approximation = enabled (kR >> 1)
I've tried to set the reference distance in "Plot mode" but nothing..
Help says:
Reference distance: Set the radius of the virtual sphere for which the farfield is calculated. Available for plot modes e-field / h-field and power pattern.
if I change distance nothing is done with the pattern, only the magnitude is changed.
Please see also the "Farfield View" section in HTML help and look at the table at bottom -> for Radial and Radial phase there's farfield approximation off!!!
Thanks for any clue!!
regards,
eirp
Hi Eirp,
if you select E-field or H field as plot mode, you can switch off the "use farfield approximation" under Farfield Plot-> general
Hope this helps,
F.
It helped me a lot!!! Sorry my blind eyes
Thanks! /eirp
PS: reply here if you have relevant comments
