Ask a question about clock tree
liujingshu
Junior Member level 1
Hi,guy
I want to ask a question about clock tree. If clock2 is divide by clock1 which is the port clock, and how to clock tree synthesis about the clock2??
hi,
in current flow, normally CTGen will synthesize clock2 tree as clock1, but if you specify that clock1 is sync with clock2 in your clock definition file, they will be balanced .
if clock2 is generated form flip flop then clock2 tree is differ from clock1 and you must leaf or exclude in flip flop by your application.
In new version tool, CSTgen can deal the devide clock, gate clock from the smae original clock cource as a clock.
for a generated clk2, do CTS on the clk2 first, and then set the clk2 root as an sync pin in clk1 CTS.
for a gated clk2, just do CTS on clk1 and no further operation is needed
combine with the design code, you can solve it in the design phase with out the balance of these two CTS
