ascii to binary and binary to ascii
umutguncan
Junior Member level 1
ascii in to binary
how can I do this with assemble? (ı use 8051 )
conversion from binary to ascii in 8051
;           Returns the ASCII codes from the nibbles of a byte stored in the Acc.
;           After being called the high nibble is in the Acc and the low nibble
;           is in the B register.
;          ;usage:
;          mov a, #byte
;          CALL nibble
;          ;returns
;          ;A= high nibble
;          ;B= low nibble
nibble:
            mov   b,a          ; b=a        ; stores Acc in B
            anl   a,#0f0h      ; a=xxxx0000    ; A && #f0h (get the high nibble)
            swap  a            ; a=0000xxxx    ; swap nibbles
            orl   a,#30h       ; a=0011xxxx    ; add #30h, if nibble is
            push acc           ; 0-9 we have the ASCII value
            push b             ; stores A and B
            mov b, #3ah        ; stores #3ah in B
            div ab             ; divide A/#3ah
            jz, recupera1      ; if zero, nibble < #0Ah
nibble1_ok:
            pop b              ; recover B
            pop acc            ; recover A
            add a, #07h        ; adds #07h to get ASCII of A-F
            xch a,b
            jmp nibble2
recupera1:
            pop b            ; stores B
            pop acc            ; stores A
            xch a,b
nibble2:
            anl   a,#0fh        ; a=0000xxxx    ; A && #0fh (get low nibble)
            jz, recupera2        ; if zero, nibble < #0Ah
            pop b            ; recover B
            pop acc            ; recover A
            xch a,b
            ret                ; return to main routine
recupera2:
            pop b            ; recover B
            pop acc            ; recover A
            xch a,b
; ASC_HEX - 	See if character in ACC is number and if so convert to a hex nibble...
A_H:
			CJNE	A, #'0', A_H1
A_H1:			JC	AH_Bad		; Is character less than a '0'?
			CJNE	A, #'9'+1, A_H2		; Test value range
A_H2:			JC	AH_Val_09		; Is character between '0' and '9'?
			LJMP	AH_Bad
AH_Val_09:		CLR	C
			SUBB	A, #'0'
			CLR	HexFlag
AH_Exit:		RET
AH_Bad:		SETB	HexFlag
			LJMP	AH_Exit
Regards,
IanP
ascii #07h
hey please clear ur question , would u like to assemble the code on actual 8051 or the simulator that support 8051 ?
how to convert from binary to ascii in 8051
next time place it in to microcontroller section
search it on 8052.com
by the way it is not possible to convert ascii in to binary and vice-versa.
but some symbol you can convert
for ex
hex no '0' represent into bin is '0000' and in ascii '30'
you just add/sub 30 in to bin/ascii you will get ascii/bin.
