peter_88
Hi guys
Actually we were suppose to do data communication through RS-232 this involved the exploitation of (UART) to set up a serial communication connection between the FPGA boards to a Personal Computer (PC) through a RS-232.
I managed to make a working UART code, the main problem is with the ASCII decoder. It should work in the following way
A system which receives ASCII codes from the PC through the serial ports, and send the translated message back to PC. The translated information is performed using a ASCII decoder, which will be designed in VHDL. Table below shows the translated message that will be sent for every ASCII code received.
and below is the general picture of communication btwn FPGA board and PC
If u guys have any code for ASII decoder plz post it here.
Thanks
Thanks
