senmeis
Full Member level 3
I’m reading the article „how to avoid Gibbs ringing artifacts in measurements“ in Signal Integrity Journal at https://www.signalintegrityjournal....avoid-gibbs-ringing-artifacts-in-measurements and have a few questions on this topic.
1. Figure 5 and 8: Do they refer to the s-parameters of the interconnect?
2. From other books I acquired the oscilloscope bandwidth shall be at least 3 times of the signal bandwidth. Is this requirement just the one this article insists (1/BW)?
3. What about older analog oscilloscopes? They don’t have a sharp brick wall filter characteristics. Do they also bring Gibbs artifact?
4. In control theory these ripples are considered as the result of a low damping ratio. Does this explanation coincide with this filter theory?
