pastro
Junior Member level 3
Hi all:
I'm working independently through "The Art of Electronics" 2nd Ed. I have a question about Exercise 2.9 (p. 84)
The exercise states:
"Verify that an 8degC rise in ambient temperature will cause a base-voltage-biased grounded emitter stage to saturate, assuming that it was initially biased for Vc = 0.5Vcc."
My solution.
From text page 81, we have
Ic = Ic0 exp(ΔVbe/25mV) (eqn 1)
ΔVbe = (-2.1mV/degC) ΔT(degC) (eqn 2)
So, substituting 2 into 1:
Ic = Ic0 exp(-ΔT(degC)/11.9) (eqn 3)
Roughly, for the collector biased to half the supply voltage, we will have Vc0 = 0.5 Vcc = Vcc - Ic0 Rc => Ic0 = 0.5 Vcc/Rc
Roughly, for saturation, we have the collector near ground, so Ic = Vcc/Rc
Thus, using eqn 3 with Ic = Vcc/Rc, and Ic0 = 0.5 Vcc/Rc, I get ΔT = -8.2degC. If a temperature rise caused saturation, I would expect ΔT = +8.2degC. However, the negative sign would seem to indicate that a FALL in temperature actually leads to saturation, which is not what the problem statement says I should find. So, what am I doing wrong? Or else is this a mistake in the book?
Thanks!
My solution.
Thanks!
