array type range constraint
Binome
Full Member level 3
Lyon, France
here's a part of my code:
  wit_process: process(rst_n, s_done)
    variable wit_addr : std_logic_vector(7 downto 0) := (others => '0');
    variable ind : unsigned range 0 to 7 := 0;
  begin
    if rst_n = '0' then
      wit <= (others => (others => '0'));
      s_wit_addr <= (others => '0');
      wit_addr := (others => '0');
    else
      for h in 1 to logl loop
        for w in 0 to leaves_nbr-1 loop
          for i in wit(w)'length-(h+1) to wit(w)'length-1 loop
            wit_addr(i) := '0';
          end loop;
          for i in 1 to wit(w)'length-(h+1)-1 loop
            ind := to_unsigned(w, wit(w)'length)
            wit_addr(i) := std_logic_vector(ind)(i+h+1);
          end loop;
          wit_addr(0) := not(std_logic_vector(to_unsigned(w, witness(w)'length))(h+1));
          s_wit_addr <= wit_addr;
        end loop;
      end loop;
    end if;
  end process;
I hope you can understand the meaning of it. When compiling with Modelsim the error is "Range constraints cannot be applied to array types." for line 3 and I don't know what to do with that.
Can someone help me?
The unsigned type is an array type, not an integer type. range constraints can only be used with integer types.
You meant to write:
variable ind : unsigned(2 downto 0);
Thank you. Making the ind variable an integer solved the problem.
