ARRAY TO PHASED ARRAY ANTENNA!
asad188
Junior Member level 2
my project is to design a microstrip phased array antenna in the microwave domain..ive designed the linear array of 4 elements and the power divider circuit nd now i have to convert it into the phased array...
i want to know the best way to do that..plzz help
nd if possible for anyone to simulate, i can attach the detailed geometry file of the array, so i can compare the reults..thx
e_m_c
Full Member level 3
Land
Let's try to do so. What is geometry?
khouly
Advanced Member level 5
EGYPT
simply to convert them to phased array , u need to insert a phase shifters before the antennas , by controlling the the phase of each phase shifter m u can control the direction of the beam
another thing , that with the phase shifters u can add amplifiers 'variable gain amplifiers' , this will add another degree of freedom to control the beam and its sideband
Khouly
asad188
specifications:
resonance frequncy is 2.4 ghz,
regular 50 ohms transmission line,
substrate height = 1.6mm
relative permitivity = 4.28
loss tangent of tan δ =0.016
iAM attaching the dimensions of the antenna, its the basic unit of the array, 2 units are attached together to form the 4 element array..
asad188
at khouly:
i mean wht is the best phase shifter, tht can easily be fabricated and varied?
another thing is, is there any possibility tht power divider circuit can change the phase as well?
khouly
EGYPT
about the phase shifter there are many types active and passive
and u have diffenet methods , like tranmission line loaded varactor , reflection type and the vector modulator
the vector modulator is based on summing the I and Q of the signal to get the specific phase angle.
u need to know , the phase shift range in the phase shifter and then select the best architecture
khouly
Abhishekabs
Advanced Member level 3
India
Depending on your budget ( cost of the product) you an decide that.
Khouly has suggested many ways, passive will be cheaper & active will add a cost.
So you have to decide based on your assumptions, such as low cost product or accurate ( expensive) etc.
asad188
the problem is that, in our original design we had to add the active phase shifting components during the fabrication, but now we hav to simulate the phase shufting first.
any way of doing phase shiting in the hfss?
Abhishekabs
India
HFSS only passive structure is possible.
You can refere IEEE papers for reference for Passive phase shifters.
asad188
can u refer me to anyone particular? and if possible give the link plzz
khouly
EGYPT
    asad188
asad188
i found a design regarding the phase shifter, its a hybrid coupler wich provide 90deg phase shift at the one output..
im attaching the schematic for the basic design, i want to know:
1) is it appropriate regarding the phase shifting thing.
2) can it be designed on the hfss
3) and will i need the power divider if i use that in the array
zfl
You could simulate the phase shifter in HFSS or IE3D.The method is changeing the phase of different port(0,90,180,270),but it will need more simulated time.wish it will help to you.
khouly
EGYPT
with this design , u will get a phased array with constant direction , coz u have a constant phase shift due to the hybrid couplers
sure u can simulate it with HFSS or any EM simulation tool , coz u have only microwave components
but u will not be able to change the direction of the beam
Khouly
jmga9
hi everyone,
I want to buil a 2.4Ghz phase shifter! because i'm making a project about beam control in an antenna array, i've been looking and cant find a good one!
So if anyone could give any link or book that could help me i'll be very gratefull!!!
Best regards,
jmga9
asad188
i had the same project, i tried a lot of designs but in my opinion the simplest way is to design a linear array with a series feed, tht gives a constant phase shift along the radiating elements and then for phase shifting u can vary the phase of input feed.
PM me ur email, ill mail u some relative thesis.
