array in VHDLfor test pattern generation
jincyjohnson
Member level 4
Member level 4
I want to store some values and then i want to retrieve it.in first clock cycle, the output of a johnson counter is xor with the first seed bit and store these in consecutive location.then the johnson codewords xor with the second seed bit.This is repeated for all seed bits.Each one corresponds to a scan chain.This is given as the test vector input or primary input to the circuit under test.How the results is stored and how it is retrieved
You have asked this before. Apparently the rather unclear question didn't bear an answer, and I fear the new one does neither.
