ARM9 interrupt handler code
bejoy
Junior Member level 2
trivandrum
ARM9 int handler
		.global  	entrypoint
		.sect	 ".handlers"
		.global	Reset_Handler,Undefined_Handler,SWI_Handler,Prefetch_Handler
		.global	Abort_Handler,IRQ_Handler,FIQ_Handler
entrypoint:
Reset_Handler:
		B	Reset_Handler1
Undefined_Handler:
        		B       	Undefined_Handler
SWI_Handler:
        		B      	 SWI_Handler
Prefetch_Handler:
        		B      	 Prefetch_Handler
Abort_Handler:
        		B      	 Abort_Handler
		NOP
IRQ_Handler:
       		B       	IRQ_Handler
FIQ_Handler:
        		B      	 FIQ_Handler
Mode_USR		.set	0x10
Mode_FIQ		.set	0x11
Mode_IRQ		.set	0x12
Mode_SVC		.set	0x13
Mode_ABT		.set	0x17
Mode_UND		.set	0x1B
Mode_SYS		.set	0x1F 		; available on ARM Arch 4 and later
I_Bit			.set	0x80	/?	;when I bit is set, IRQ is disabled
F_Bit			.set	0x40	/?	;when F bit is set, FIQ is disabled
Len_FIQ_Stack                	.set	512
Len_IRQ_Stack               	.set           512
Len_ABT_Stack                	.set           512
Len_UND_Stack                	.set           256
Len_SVC_Stack                	.set         1024
Len_USR_Stack                	.set         1024
Offset_FIQ_Stack                     .set	0
Offset_IRQ_Stack                     .set          Offset_FIQ_Stack + Len_FIQ_Stack
Offset_ABT_Stack                    .set           Offset_IRQ_Stack + Len_IRQ_Stack
Offset_UND_Stack                    .set          Offset_ABT_Stack + Len_ABT_Stack
Offset_SVC_Stack                    .set          Offset_UND_Stack + Len_UND_Stack
Offset_USR_Stack                    .set          Offset_SVC_Stack + Len_SVC_Stack
Reset_Handler1:
		LDR     r0, stack_s	//r1
		MSR     CPSR_c, #Mode_FIQ | I_Bit | F_Bit 	; No interrupts
		SUB     sp, r0, #Offset_FIQ_Stack
		MSR     CPSR_c, #Mode_IRQ | I_Bit | F_Bit 	; No interrupts
		SUB     sp, r0, #Offset_IRQ_Stack
		MSR     CPSR_c, #Mode_ABT | I_Bit | F_Bit 	; No interrupts
		SUB     sp, r0, #Offset_ABT_Stack
		MSR     CPSR_c, #Mode_UND | I_Bit | F_Bit 	; No interrupts
		SUB     sp, r0, #Offset_UND_Stack
		MSR     CPSR_c, #Mode_SVC |  F_Bit 		; No interrupts	I_Bit |
		SUB     sp, r0, #Offset_SVC_Stack
		LDR		R0,op1_s
		LDR		R1,[R0]
loop:	B	loop
stack_s		.word	 top_of_stack
op1_s		.word	op1
        	.sect  ".stack"
top_of_stack:
			.sect ".math_memory"
op1		.word	0x12345678
op2		.word	0x23456789
res		.word	0x00000000[color=red][/color]
What is your question?
Amr
can u pls give me an idea on the address range that i can branch to from this function.
while linking in certain range i got an error that it exceeds 24 bit value
Send the complete log please.
Amr
i shall send the detailed error 2orrow.
it was saying that u cant branch to a location whose address exeeds from present by 24 bits.
when i wrote that piece of code in main it was cleared.
i would like to know is there any alternative way to handle such situations
I have 2 c the code and know your compiler.
Amr
its code composer studio
there z no error in the code.
i occurs when we call a function which we have maped to certain location in the linker command file.
the location in the linker file creates the problem.
i read in the user guide about some 24 bits are used for address calculaion.
i wud like to know any alternative other than changing the mapped address in linker
The 24-bit offset is a hardware limitation of the Branch instruction. It is a rule forced by the ARM architecture itself.
Why this function has to be in that certain location?
Amr
ok i just want to know is there any tricks ....
Added after 16 seconds:
thank you
You can do a self modifying code that branches to a certain location and at this location , there is a a function that can load any address to PC.
Amr
